Brewz
- 7:48 PM
- Jan 16, 2016
- Hunter Valley - Australia
Will see what it is when its on the bench
Fantastic info
I will discuss all this with the owner when I see him.
What is the 3120 coil limited to?
I believe someone mentioned using a husky 61 coil as well as it has the correct timing.
I don't think he wants a hotrod, just wants the saw to run like a big saw should.
Did it have the gasket behind the exhaust Brewz ?I stripped her down today. Its done NOTHING work wise.
hit it with a bit of degreaser and hosed it all off and its like new.
The muffler was loose when the owner bought the saw and apparently it came loose again after 5 minutes use and its done nothing since.
Quite a bit of damage to the back of the muffler and the cylinder but a file will fix that up just fine.
Carb appears to be a WG8 and does not have the primer bulb.
I have not opened it up yet byt will be ordering a set of micro drills tonight.
Also, the coil is black so 12500 it will be.
I don't think I will need it to run any faster. It wont be a race saw.
NoDid it have the gasket behind the exhaust Brewz ?
Having the proper compressible gasket has usually sorted out that issue with saws that have come to me without. I have tightened down.. then left the saw to cool and just a little bit of a final torque down (just like engine head bolts ).No
Owner said it was loose when he got it so he tightened it down but it came loose very quickly so he stopped using it and its sat ever since.
I will be ordering a gasket.
The cylinder and muffler flanges have come up nice after a bit of a file
