JT78
- 4:03 AM
- Aug 29, 2016
- Burlington, nc
If a bar uses 104 dl of 3/8 how many drive links of .404 will I need? 32 inch solid nose bar.
It's a hard nose McCulloch bar so no sprocket just trying to figure out how many DL of .404 to start at. It's going on the 797I have to agree with Pincher. Best bet is that this bar is a 32"and takes 105 DL's. A 32" bar that uses .404" pitch chain wants 95 drive links.
I do not recommend using .404" pitch chain with a bar that has a 3/8" pitch nose sprocket. I doubt anyone else does either.
Ryan, I am lost after reading your reply. OP is talking about increasing the pitch of the chain from 3/8" to .404" and using the same 32" bar, not shortening the chain.It takes less work and presets to shorten a chain then it does to lengthen one. I like to err on the long side if I'm guessing.
He is talking about spinning a chain for a certain bar. So, he’s suggesting to be a dl long rather than a dl short.Ryan, I am lost after reading your reply. OP is talking about increasing the pitch of the chain from 3/8" to .404" and using the same 32" bar, not shortening the chain.![]()
Yep and if it's for a stihl 7 pin you just need 6 dl clear of the bar groove and job done .I just lay the bar and sprocket on the bench and wrap the chain around it. Give a fuzz extra and call it good.
When it gets to hot and starts smoking, ur doing something wrongTry 95 DLs as Pincher and I recommended. But, not many hard nose bars that long do very well. Heat builds up and smoke start showing up. Make sure the saw's bar oiler is wide open. Good luck!
Yep you definitely do not run them like a Sprocket nose that's for sureWhen it gets to hot and starts smoking, ur doing something wrong
42“ hardnose is no Problem when u make the chain tension right![]()
And that is the problem.Yep you definitely do not run them like a Sprocket nose that's for sure
