SELLING 2nd 262 crankcase
trooney
Admitted Woodaholic
4:31 PM
The land of pleasant living
selling crankcase #2. Crankcase is already split. It is in good shape. However, I have no idea what they were trying to accomplish with the clutch cover tabs. They wallowed out 1 and started on the other, but it does hold the clutch cover. Also, the two back cylinder cover holes are wallowed out, and if I remember correctly tapped out for 6mm. Dont know if you can put an insert in them or not. Or fill with jb and redrill. Those that are more handy than I might know. But its a good case otherwise. $25 plus ride.image.jpegimage.jpegimage.jpeg
trooney
Admitted Woodaholic
4:31 PM
I found another PTO side case. Screw hole accepts the screw that it was intended for it. However, instead of acepting the plastic side cover it accepts the metal one with the peg that goes into the case. All for the same low price.image.jpeg
