- 6:32 AM
- Jan 8, 2016
- Farmington, CT
Uh...if you don't buy that in the next ten min I will
Hey, you warned me, haha!Well...someone got it. Damn.... I wanted that.
It's a mundane and not hardly needed screw, but the short Phillips screw in the pic might be (the regularly flat head screw) that secures the rear tab of the intake horn to the case. Not sure if low top intake horn has the same rear tab as the high top intake horn for the HD filter.Ordered deflector. Realized I need a Op pres lever. Moment of weakness and ordered a full wrap. Never have sat down with the IPL or tried to assemble, keep getting side tracked. Need to steam clean some more stubborn crusties off and then I’ll assemble. Have bearings seals gaskets carb…
288 nerds: what hardware am I missing
I think I have a can of OEM Husky paint floating around if you want it.Wow, I was mostly kidding on the bolts but looks like you guys do have it down. Convenient you just went thru one Ben. Ordered OP lever and loaded clutch cover last night. Guess I better get going. Gonna be a funny half and half mix of ugly and new parts, ha! Maybe I should paint the cases. I also need to scrounge up bolts for the starter. I probably have some. Then some helicoils or keenserts…
I think it's gonna match my truck.I think I have a can of OEM Husky paint floating around if you want it.
Desert tan cases? That'll be different.I think it's gonna match my truck.
bigger truckDesert tan cases? That'll be different.
