- 9:10 PM
- Jan 24, 2018
- Extreme Southeast CA
By golly, there is a heat shield on those saws! I'd have sworn there weren't any on the 181/281's I tore down, but the ipl said otherwise. What throttle lever do you need? I'm only aware of one, the all plastic "pusher" style, and to the best of my knowledge the only change in those was black plastic on early ones being changed to grey plastic for later ones.That top would be pearls in a pig’s snout! I might have a way to make the rest look half decent.
@Mattyo was kind enough to write that exhaustive list up based on my vid with his more 288 experienced eye.
For right now I just wanna get it to run...full build after the 61/266/272 builds
So that mainly means ignition parts.
Different throttle lever that will jibe to this carb.
I’ll order a carb kit.
I guess I need to sit down and swap the cyls and put as much of it together as I can to see what bolts I’m missing. I have a decent selection of metric bolts at work, we’ll see how far I can get.
Exhaust shield.
I probably have a switch around I can use.
I think I have some 266 and maybe 395 tensioners but I don’t know if they will fit.
Nuts for the air filter?
Flywheel shroud.
Or you could mount it to the inner dog.btw, you CAN use that roller catch in the same spot as the aluminum 372 chain catch goes. just have to mod it to fit... takes a bit of work but its worth it.
Oooh, that's nasty!Add a carb to the list View attachment 302013
This guy's price is a little easier to stomach, methinks.See the link above for a new carb....
