288 carb mount
paragonbuilder
7:11 AM
Norwich, CT
I'm working on my FIL's 288, and noticed something I dealt with on my 181 as well.
It seems that the entire carb and intake tract needs to drop to line up properly. This picture is with a gasket delete, but even with the gasket it seemed like it should drop. When porting and cutting the base, this must be worse.
How do you deal with this?
I considered tapering the intake block slightly, but then the screws won't be lined up correctly. Only other solution I see is to trim the "support" for the Intake block, and clearance the carb floor for it to drop.
Thoughts?
awol
6:11 AM
Cabool, MO.
I have this problem on all of the 281/288 saws; if you drop the jug far enough, the carb will even bottom on the fuel tank. My cure is just to mill the intake surface at a slight angle. A large flat file works well. The screws still work ok if you don't go to far.
paragonbuilder
7:11 AM
Norwich, CT
So to be clear, taper the intake surface on the jug? Not the intake block?
awol
6:11 AM
Cabool, MO.
Yes, I do the surface of the cylinder; the farther away from the pinch point you change the angle, the less changing you will have to do.
srcarr52
7:11 AM
Iowa City
Trim the sealing lip for the boot around the intake block with a die grinder. If you dropped the jug a lot you'll need to trip the rubber seal too.
paragonbuilder
7:11 AM
Norwich, CT
Thanks Shawn. I did find I needed to do that. I took about .040 off the top of the intake flange to eliminate the pressure on the intake track. Then I trimmed the rubber seal. Everything looks tight and true now. Sealant is curing, I'll find out tomorrow if she's sealed up good...
Hooray 288!
paragonbuilder
7:11 AM
Norwich, CT
Well I fired her up this morning and she tuned perfect. Cut with her a bit this afternoon and something felt off. Brake cleaner found a leak where the carb meets the intake block. So either it still has to drop, or the gasket I reused failed. I'll know tomorrow...
