paragonbuilder
- 7:11 AM
- Jan 2, 2016
- Norwich, CT
I'm working on my FIL's 288, and noticed something I dealt with on my 181 as well.
It seems that the entire carb and intake tract needs to drop to line up properly. This picture is with a gasket delete, but even with the gasket it seemed like it should drop. When porting and cutting the base, this must be worse.
How do you deal with this?
I considered tapering the intake block slightly, but then the screws won't be lined up correctly. Only other solution I see is to trim the "support" for the Intake block, and clearance the carb floor for it to drop.
Thoughts?
Thoughts?
