262xp AV mount???
pro94lt
4:54 AM
South
Any tricks to get this rubber AV mount out on the tank? It's broke, I see no bolt holding anything together from the other side??? image.jpeg
Warped5
4:54 AM
Northwest IN
There should be a removable screw at the other end of that spring. Remove it and 'roll' the crankcase off the tank, PTO side toward the flywheel side. That AV mount is just a nub that goes in the hole.
cus_deluxe
terms of service violator
5:54 AM
Michigan
Those rubber mounts are specific to this saw as well i think, but guys smarter than me pointed out that the rubber mount in the same spot on 257s works nicely when trimmed to length.
cus_deluxe
5:54 AM
Michigan
You may have to use some good needle nose pliers to hold on to the remnants of that rubber mount to get it to keep from just spinning.
pro94lt
4:54 AM
South
I took it off, but could not find a Allan head in their from the other side. Swapped the upper mounts to the rubber ones. I wanted to try the feel of the rubber so I put it back together lol I'll pull it back apart. image.png
cus_deluxe
5:54 AM
Michigan
I prefer the runber mounts, springs are a little floppy for me. Theres gotta be a screw in behind that rbber mount. Did you get all of the rubber out?
Welder56
6:54 AM
Nova Scotia
I believe the proper name for it is an 'absorber'. I ordered one from the dealer. It was on back order and took about 2-3 weeks to get to me.
Figured this could help if you can find one online
pro94lt
4:54 AM
South
I was thinking the absorber had a screw holding it in. It didn't, just a tight fit. I took a mount from a 288 put it in a vise cut to length, and had to grind just a little off of the rubber. Fits in great and what a difference! If you've got a 262 check it! The only reason I found it was because I was going from spring to rubber
Welder56
6:54 AM
Nova Scotia
Mine also didn't have a screw, just needed to spit on it first ;)
Glad ya got Er tho man
pro94lt
4:54 AM
South
Take the handle off also. No point fighting it.
Sorry I posted a misleading pic and made it look like I was trying to get it out with the tank still installed. You guys thought I was that guy. I'm not that guy. Lol
