261 M-Tronic - What makes it tick.....
breese
11:58 AM
Chicagoland, Illinois
Next phase:
Now that I know where different components are located and an approximant depth, I will be using one of the other coils and begin milling down to the CPU.
Once I have access to the CPU and traces, it should be possible to reverse engineer the CPU and or find any markings indicating what chip it is...
The other side of this is it should also allow the coil to be powered up and tested for power and data lines.
As for some of the questions that have popped up:
Increased RPM might be a benefit but, finding an holding RPM within the best power range at WOT should produce a stronger saw within the cut....
Right now there are too many questions on what this actually does, how it does it, and just how much information does it store....
One thing I am positive of IF the documentation is right, there is a writable section within the chip or the software would not have Reset availability.
Brush Ape
Direct Connection
11:58 AM
Metropolis, Il
It would make more sense to me if that is actually a variable position plunger being pulled open (against a light return spring or not) by a small electromagnetic coil.
Would Pintle Valve be the 15 cent word here? (Split infinitves are highlighted in Stihl orange.)
FergusonTO35
12:58 PM
Boonesborough, KY
I'm reading all this with interest. I was an auto mechanic for my first career, and the workings of the M-tronic system is more what I am used to than regular carbs. As much as I love my little 1955 tractor, there are times I would love to drop a modern EFI Toyota engine in place of the stone age Continental Z-134. One question: does the M-tronic system store power for the ECM in some way, or does the first pull on the starter cord power it up?
breese
11:58 AM
On the pull of the starter...
There is no power storage. The 2 capacitors I have located are not directly related / connected to the CPU.
The addition of a battery type power storage would have many downfalls one of them being the heat generated by the saw and the 2 power coils within the whole coil.
Redfin
Meh...
12:58 PM
Central Pa
breese
11:58 AM
I believe that the fi system has a generator under the flywheel, mt does not
The entire system is charged by way of the flywheel.
This is a Magneto type system. The magnets on the flywheel transfer energy to the pickups on the coil pack (this is why the spacing between the coil and flywheel must be very close).
Next the energy is transferred to the larger of the 2 coils within the coil pack.
From the lager internal coil, the energy (voltage) passes thru (in simple terms) to the smaller coil and the voltage is raised high enough to fire a spark plug (somewhere between 5 and 10 thousand volts the last time I checked).
As the flywheel rotates, and the piston hit TDC, there is another pickup on the coil pack that when triggered allows the coil pack to now Fire the sparkplug.
By modifying the key between the flywheel and crank, you are moving the trigger point that the second pickup is seeing, there-by resulting in the advancement of timing you are seeing in your other modified saw builds.
The M-Tronic has the ability (internally) to Delay or Advance the firing of the sparkplug as it monitors the second pickup and logically deciding when to fire.
Now, because the coil pack is storing energy (voltage) created by the Magneto, the M-Tronic coil (internally) uses some of this power to supply power for the built in logic. This is not new. All single unit electronic ignitions have been using part of the power for internal logic. The M-Tronic is just using more of it to supply power to external sensors, coils, etc....
