dustinwilt68
Wilt Built Work Saws
- 6:39 AM
- Mar 8, 2016
- Southwest PA
#Dallisback
What are you doing to it?i tore my 261 m tron apart last night.
Not really honestly she runs but im in process of rebuilding it needs new piston gonna put new seals.im trying to soak all this in and learn what you are doing very interesting thanxWhat are you doing to it?
Anything related to this thread?
Normally I would agree... But in this case, we have both power (9v) and data going across the line.Its just shorting the two wires![]()
Ok... So inside the switch assembly is a diode.Its just shorting the two wires
I will askDoes anyone know of a dealer or repair place that has a dead or believed to be bad diagnostic cable?
The one that connects the computer to the saw....
There ya go...Right now (without a diagnostic tool) here is what I know and will also try to explain a few things.
As I said before, there are 2 sensors on the Coil pack that are spaced away from the fly wheel. One is the magnet coil that gets its energy / voltage (DC) from the magnet on the actual fly wheel... You can think of it in simple terms as a reverse alternator. Instead of the Rotor with windings spinning within the magnet pool, the magnets spin and the pickup gets the energy.
The second contact is a trigger that corresponds with TDC. If you pull the flywheel you will see a section with magnets and another smaller section that looks like it might be a magnet. This smaller one is what the coil pack uses to understand TDC.
Internally I have found the coil pack is extremely smart.
Each device that connects to the coil pack has a built in slave ID. So a carb might have a built in ID of #254, a temp sensor of #056 and a future sensor might have an ID #126.
Because of the hardcoded ID's the CPU will have knowledge of the device, what it is, how to communicate to it, and know how to use that information to best serve the saw.
The CPU/ECU has the ability to monitor multiple sensors and or devices. This explains how the Carb solenoid is able to open and close anywhere in the range of 0% to 100%.
What I do not understand (yet) is how it knows how much to open. At the moment I do not see a sensor telling the system what the current Airflow is.
My best guess is that my monitoring the RPM (also done thru the coil pack by using the TDC trigger), it makes small but very fast decisions on the amount of fuel to supply and reacts either increases or decreases fuel based on that RPM.
In Stihl's own words for WOT "The resulting engine speed pattern is analyzed by the microprocessor"
NOTE: There is a newer version that actually has a switch on the carb choke shutter for start detection.
Depending on the available commends within the CPU in the coil pack, it should be possible to add other sensors, devices, and change the programming and or device info so as to retrain / learn / or anything thru it.
The Diagnostic kit and its built in electronics is going to be the key.
I am still studying the CPU in the coil pack for more clues...
