ECHO 2511T air filter modification
Saw Collector
OPE Member
4:41 PM
Here
IMG_20200129_093213.jpg IMG_20200129_093230.jpg IMG_20200129_093245.jpg IMG_20200129_093303.jpg I've read and watched videos where people get fine particles in the carb throat on the 2511T. Gets past the filter to carb flange mating surface I believe. The filter fits a bit loose. I took steps to stop that before it could happen to my new Mastermind ported pocket rocket. First I removed the flange that the filter twist locks into and put a thin layer of grease on the back, where it interfaces the carburetor and reassembled. Next I made a foam "gasket" from air filter material and oiled it with Belray foam filter oil. I then sandwiched it between the filter and the flange. I removed the filter a few times to make sure the foam didn't get forced into the carb opening when twisting the filter into place. The filter fits much more snug now. So far so good. Clean as a whistle.
Saw Collector
OPE Member
4:41 PM
Here
I have another plan up my sleeve but I need to get a spare flange and filter cover before I go messing around.
NeSurcaster
4:41 PM
South Jersey
I'm used to running stihls at work so the few fines that get past my 2511t don't bother me much. I just try to tap filter off every other tank and wipe off around carb throat. 2511t compared to 461/201t/661 isn't comparable for the amount of chips/fines that get past filter.
full chizel
¯\_(ツ)_/¯
4:41 PM
USofA
Same thing i do
Stubnail67
4:41 PM
florida
I did a similar mod for my 2511t with foam as well it works great...i bet with grease added its even better i used grease an o-ring but the foam did the trick...
Saw Collector
OPE Member
4:41 PM
Here
I'm also going to try an external air filter from a 1/5 scale rc car. Ill need to get a new cover and mounting flange for the filter. I plan on drilling a hole through the cover and have the modified flange extend out through that hole to clamp the round rc filter on. It's a cheap and easy experiment. The saw was ported by Mastermind so maybe more air will make even more gains. Its already pretty angry as is.
Stubnail67
4:41 PM
florida
I'm also going to try an external air filter from a 1/5 scale rc car. Ill need to get a new cover and mounting flange for the filter. I plan on drilling a hole through the coverand have the modified flange extend out through that hole to clamp the round rc filter on. It's a cheap and easy experiment. The saw was ported by Mastermind so maybe more air will make even more gains. Its already pretty angry as is.
mine is stock i use it for palms so no need for it to be modded except to run cooler.... any videos of your before and after? did mastermind make any on his youtube?
Saw Collector
OPE Member
4:41 PM
Here
No vids. I sent it brand new with only 5 or 6 heat cycles to break it in. Randy called me because he was really happy how it turned out. Said it will cut circles around his personal ported stihl ms150. I had no trouble pulling the factory 12", 3/8 .050 lp set up in frozen green cherry 10" dia. No chatter. I had already purchased a 12" .043 bar and 2 new chains anticipating the chatter that people encounter. He cut 6" oak and me the cherry without issue. It will rev to 14,500 no load but makes the most power around 14,000. Still 4 strokes out of the cut at 14,000. Its a little monster.
CR888
6:41 AM
Its good to see the wee saws getting port work. They often don't get worked on as they are tiny & good work costs about what the saw does. But they 25cc needs all the help it can get and would be really noticeable. Good little saws them 2511's, Echo hit a home run with that saw.
Saw Collector
OPE Member
4:41 PM
Here
It's definitely an impressive lil bugger for sure and fits my needs perfectly. They come from the factory with a domed piston and the squish band at an angle. Randy was really impressed with the rpm it holds in the cut after he finished his port work. He ran a tank through the saw cutting up a 6" white oak he fell and lopped it up into firewood.
Cerberus
Cerberus the aardvark, not the hell-hound!!
4:41 PM
Florida (tampa area)
View attachment 220936 View attachment 220937 I've read and watched videos where people get fine particles in the carb throat on the 2511T. Gets past the filter to carb flange mating surface I believe. The filter fits a bit loose. I took steps to stop that before it could happen to my new Mastermind ported pocket rocket. First I removed the flange that the filter twist locks into and put a thin layer of grease on the back, where it interfaces the carburetor and reassembled. Next I made a foam "gasket" from air filter material and oiled it with Belray foam filter oil. I then sandwiched it between the filter and the flange. I removed the filter a few times to make sure the foam didn't get forced into the carb opening when twisting the filter into place. The filter fits much more snug now. So far so good. Clean as a whistle.
Thanks a TON for that, I use all kinds of various ways to ensure "no fines" and there's nothing better than stumbling-upon a ready-made solution :D
In your 1st picture, looking at the inlet-perimeter of the carb-throat...can't help but think of flaring that out a lil, will have to measure the throat versus the air-filter's fittings!
Have 60PPI (or 80pore maybe?) foam to cut-to-fit for this, thanks again this looks like the cleanest fix! As you can see I'm a bit OCD with my filtration:
https://opeforum.com/threads/660-air-filter-fix-for-fines.25236/#post-1326611
To be clear, do you mean Stihls are better or worse? I posted a link ^ in prior paragraph with pics of how I do my air-boxes, so I really wouldn't know because all my stuff has 'pre-filtered' airbox-inlets (I filter the OEM inlets as well, of course...this lets me run no pre-filter or "sock filter" over the filter w/o needing to clean or change it every hour!!)
I have a whole box of o-rings, grease, foam etc for filters, seems every saw's needs are different and virtually NONE seal properly off-shelf (have heard the 7310 echo is quite impressive here, youtuber @mweba1 has a "46 tank review" and the airbox itself is still VERY clean, w/o any fines having gotten-past!)
Gotta love palms....so wet, so destructive to saws (the manual w/ my 2511t was 1st time I saw an OEM advising to be wary of this, being in FL I've learned it long-ago, the hard way...so many clutch-bearings / etc gone before their time!!)
It's true...but at the same time you could say these lil ones need it the most, I mean not only does power//weight matter more for your main climbsaw than, say, one of your groundsaws, but powersaw power-per-displacement goes up (at least through 100cc's) so lower-displacement saws "should need it more" especially climbsaws!
(Note-- I found it interesting that, of every saw I own, the 2511t is the sole powersaw that doesn't adhere to the "more horsepower-per-CC, the more total displacement in the powerhead" rule!! It eeks-out the 50% larger 355t by a lil bit, very impressive and that's OEM spec 1.5HP which we all know is boosted like 15-20% just by addressing the obnoxiously-choked muffling of this saw!)
I was interested in the big bores as well but, have read many posts and talked to many ope members who say the BB's don't increase performance and can actually hurt performance. Most of it having to do with either freeporting issues or something to do with case volume not being sufficient enough to flow well. The intake tract for these saws are fairly small as well. Most of the "Duke" parts are sourced from the same place farmertec gets their parts. So... I would not be surprised if you order a cylinder from them and it is the same as the one you would get from farmertec. I would probably go with the hyway cylinder if I was to try one. They should be a direct bolt on. No modifying bolt holes.. I think I remember the post you are referring to and it was either a prototype jug or they were bolting it on an 064. The "magnum" badge is mostly a marketing thing. Some saws like the 038 had "mag" and "super" models that were larger than the base model 038.
My latest saw (660 #4) seems to run very well. I have a non modified 660 I'm going to compare it to. Then I'm going to take the non modified one down and do port work and a hyway pop-up.
