242xp resurrection. (My first 2xx series) Build Complete! Vid added!
RIDE-RED 350r
11:32 AM
Blossvale NY
OK fellas! My new Performance Saw Supply piston arrived from Lil Red Barn today. At first glance it looks very close to the OEM piston because well, it IS VERY close to OEM dimensionally speaking. It is windowed and seems to be of pretty darn good quality. The only obvious difference at a glance is that it does not have the offset intake skirt but strangely enough the intake skirts seem to be the same width, I checked twice. I took a few pics and will post dimensions as best I could measure with my caliper in the next post.... IMG_20170522_171942962.jpg IMG_20170522_171958582.jpg IMG_20170522_172040193.jpg IMG_20170522_171923424.jpg
RIDE-RED 350r
11:32 AM
Blossvale NY
OK, so I will refer to the Performance Saw Supply piston as "PSS", here is how the measurements shook out. The only measurement that may have a little error is wrist pin to crown as the crown is slightly domed, I tried as best I could to measure both pistons in the exact same way, the wrist pin bore being recessed made that a little tricky but I think I got it pretty close.
So here it is:
Overall height: OEM- 1.344" (34.13mm)--------PSS- 1.338" (33.98mm)
Intake skirt width: OEM- 1.145" (29.08mm)-------PSS- Same
Exhaust skirt width: OEM- 1.150" (29.21mm)-------PSS- 1.145" (29.08mm)
Pin to crown: OEM- .550" (13.97mm)-------PSS- .545" (13.84mm)
So, it seems there is about .005"-.006" (.12mm-.15mm) difference in overall height with the PSS piston being shorter and that difference seems to be at the pin to crown measurement. This is pretty darned close if you ask me. This MAY be a good viable 242 piston being so very close to OEM dimensions. Looks like a BG delete should easily make up the difference and then some for added compression over stock configuration with the gasket in place. :)
What do you guys think?
RIDE-RED 350r
11:32 AM
Blossvale NY
Shoot, forgot to get a side x side pic of the windows on them... Stand by....
rattler
11:32 AM
NC
If I didn't have other things to tend to yesterday, I could have spent many more hours in your shop.
I really enjoyed my visit. Thanks Mike!
Sorry to derail. Carry on RIDE-RED 350r.......
You are Welcome you come back any time always welcome I enjoyed it too wish it had been dryer.
Sorry Red I'll hush now.
Sent from my SM-G935V using Tapatalk
rattler
11:32 AM
NC
Is the new piston a dome?
CJ Brown
11:32 AM
Belleville, Ontario, Canada
To accurately measure top of pin to top of piston, install the pin half way and use the depth measuring feature on your calipers to take the measurement from top edge of piston to top of pin. If your piston is domed and your squish band is flat you need to be careful measuring squish. You could always glue sandpaper to your domed piston and sand the squish band to match your piston profile.
RIDE-RED 350r
11:32 AM
Blossvale NY
It seems ever so slightly domed. Thanks for the tip CJ, I didn't think of that. I think I got it pretty close though as the pin to crown measurements pretty much agree with overall height difference
RIDE-RED 350r
11:32 AM
Blossvale NY
Just to let you guys know I haven't abandoned this project, just been sidetracked by a flurry of vehicle repairs that tapped my extra spending money and just got home from a ten day family camping trip in the Adirondacks. I have a couple more repairs to make on my winter truck and then I'll be resuming this project. I'll be ordering my gasket set, flywheel side crank bearing and seal as well as some other odds and ends soon....Plus I might be looking for a couple of misc used parts as well.
Since we last chatted here, have any of you other 242 guys tried a PSS piston yet?
David Young
Safety First !!!!!!
11:32 AM
vt
Hey another thing to always service on these is the prefilter that is in the case. you never hear much about them.
you mind taking some pics and showing everyone?
David Young
Safety First !!!!!!
11:32 AM
vt
remove the screw where the arrow is dot dot dot
most will have a surprise in there.
here is a hint, its a nylon mesh pre filter.
I hope I haven't said too much
Tor R
Novice, Leg model #2
5:32 PM
Mandal
no one cleans them out. everyone i have ever seen needed to be cleaned...
David is correct, 95% of those 133-242-246 owners never clean the prefilter.
Wish I had taken picture of the prefilter to the 242 I bought on Sunday, the whole area around the prefilter was totally clogged, owner fix was to remove the winter plug though :D
Tor R
5:32 PM
Mandal
You should probleby check if all those parts are still avaible, more and more parts is NLA.
