2260 bearing fail
2:37 AM
I use heat to seat bearings in the case. Should I not be doing this??? I’ve never seen mag shavings after an assembly but if there’s a better way I’m all ears.
Yes heat like Joe said. That's the way we doing it at work and them bearings cost more than these saws lol.
Tor R
Novice, Leg model #2
9:37 AM
Mandal
heat is our friend, continue to heat up the case before you slide in them bearings and you will be fine.
This cold pressing technique is something Husky do, I woudnt recommend it at all, the number waranty's they has due blown bearings & cranks is probleby good enough reason to unvoid cold pressing.
tree monkey
2:37 AM
wi
3:37 AM
Looks like its fits an output shaft for a cruise ship. Lol
Johnmn
2:37 AM
Minnesota
Is this a 5 or 6 bolt case? Or is that not the issue here? Has the underlying issue always been cold pressing?
