201t c stalls in cut
Nutball
8:33 AM
Mt. Juliet, TN
After only a minute of cutting this 201tc dies. I don't think it is a long enough run time for it to overheat, but it shuts off like an error triggered it. It seems to only happen under full load.
What are the likely causes and recommended solutions? Does the Stealer usually charge much to plug it into the computer?
walkdog
6:33 AM
Bay Area
IME you’re probably looking at an mtronic module or coil issue.
If you haven’t already, definitely try the appropriate mtronic reset before taking it in.
If you have a good dealer they’ll look it over for you for free, but there are many that will immediately insist that the only fix will be to slap in a new carb.
Nutball
8:33 AM
Mt. Juliet, TN
What is the reset procedure and the serial number break if there is more than one version of reset? I tried what I think is the most current procedure from memory, but got nothing.
