2011 husqvarna 562 high end bog/stall???
angelo c
Coal Member
7:35 AM
It's the carb.
It's a known fault. @Mastermind has a fix for the el-46 and a gooder answer is the el-48.($75)
I would start with a reset of the computer.
Keep in mind this is a "blonde" saw...
You know....looks great, feels great to take her out on Saturday night, all yer friends think she is great, but man she is dumb as a rock when it comes to "actually" doing something.
6:35 AM
Two things.
First pull the muffler. Make sure it ain't been straight gassed. Could save you a lot of trouble.....
Second, it's probably the carb. If the piston looks good, contact Bob (spike60). He can hook you up with a new carb that is programmed to the saw.
Backtroller
6:35 AM
Land of Badgers
Looks like a new carb is in order. Crazy that you need a new carb programmed to the saw. I don't own anything that high tech (atleast in saw form). Curious to see how it finally runs after you have it sorted out.
panteliss
1:35 PM
Europe
It's the carb.
If fall a blond and a dark hair from a skyscraper who rich the ground first ?????
A FREE 562 if you find the answer
Red97
7:35 AM
MI
many say that the 6100 is the stronger in the category ...... but we have the stihl lovers the husqy lovers and the dolmar lovers
Going to run a muffler modded 6100 to see if I want to bother buying/finding one.
I don't care what brand they are, just gotta find the one I like best. Currently this 562 is not it :)
7:35 AM
i dont want a mtronic or a autotune saw they are adding to much junk and trying to make them to complicated for the average person to work on
cgraham1
4:35 AM
Nor Cal
I know this sounds stupid. But are your carb bolts loose. Local husky tech told me to check mine along with lines.
Its a Husqvarna, so probably should go ahead and check all the bolts.
Two things.
This just pisses me off to the point I will never have another 562. They put a *s-wordty carb on it at the factory, and then charge you $100+ to get your saw running the way it always should've run. Every f*cking one of these should be replaced, at no cost to anyone but Husqvarna. *a-holes.
johnny5ny
7:35 AM
Saratoga Springs NY
It's not even fair how far ahead the 562xp is of the others in its class.
I know, I know.....fanboy.....BUT,
I would agree with anyone that the bog/carb issues are unacceptable and had I experienced any of them (zero with mine) I would likely be less loyal to husky/jred than I am.
Get the carb issue squared away @Spike60 and report back. My ported 562 beats the ever loving balls off my muff modded 372 all the way up to a 20" bar.
Red97
7:35 AM
MI
Still up in the air bout the mtronic/autotune.
Have a stock 261c not impressed. And this one. Well the thread spams for itself.
Yes.
And
Yes.
That sure would be nice.
