200T kill switch PN# help
angelo c
Coal Member
6:44 PM
Looking for help with 200t kill switch wire part #. My dealer can't locate the entire yellow/ green wire that's in the top handle to complete the "shut-off" switch. I see 3 separate #'s for the wire but not 1 part number for the entire wire with both ends already completed and ready to connect. was always able to order 1 part for complete wire before now he says can't find it.
part numbers 23-24 and 25 listed below. Used to come complete. Anybody know a PN ?
DND 9000
12:44 AM
Germany
Item 23 is market as (D) (not availible as separate item) You have to buy item 22 contact spring (1129 440 4000), that comes togheter with parts 23-25. Also part 24 and 25 is market as (C) no longer availible as individual parts. That means part 24 and 25 are only availible together as a set if you buy the contact spring.
angelo c
Coal Member
6:44 PM
Thanks for the reply. So if I have this correct, I purchase "spring" 1129 440 4000 and I get the wire and plugs with the spring ? So the only change is I now have to purchase the spring to get the correct connecting wire with ends.
Again thank you...my parts guy is good....but better for mower parts then saw parts
DND 9000
12:44 AM
Germany
Yes you are right. The contact sring comes with the ground wire (no part no.) and 2* terminal socket (part 24 and 25 on the drawing) These 2 parts have a part number, but with the marking (C) which means no longer availible as spare parts. Have a look on my file attached.
DND 9000
12:44 AM
Germany
Some more information. This contact spring (and included parts) should be availible up to 2021.
angelo c
Coal Member
6:44 PM
Can't thank you enough...my IPL does not have that listed the same way. Older outdated mediacat version I guess.
Cheers.
