Nutball
- 12:20 AM
- Oct 31, 2018
- Mt. Juliet, TN
This bar is for the working man. If you are a working man, then this bar is for you, and you will have to work it before you can use it because the rails are different heights (poor lamination alignment) and need to be ground square,and the rails also stick out too far on the tip which will just burn the tip until it wears down unless you grind the tip.
I got this thinking it might fit a ms250, but it doesn't, so I have no need for it. I tested my new rail closer on this, and it did close the rails down from about .068-.080 to about .062-.067
$6 buyer pays shipping
