16 techlite bar question
lilbenny
New OPE Member
4:35 AM
Clearfield, Pennsylvania
This is a techlite 16" bar, 3/8, that fits the T540xp. Ive found that it is a k095 mount an has a 8.2mm bar slot. Will this work on a 357xp/359, or anyway to make it work?
lilbenny
New OPE Member
4:35 AM
Do you have a small mount husky saw to try it on other than your top handle ?
I just have a 359. Im looking for a 16" bar that is 3/8 for it and I came across that techlite bar, but it is for the top handled saws. Through searching I found the bar is a small mount, but everywhere I look it only confirms the bar will fit the top handled saws and not any other saws.
Termitebuffet
Home of the corn can muffler .....
4:35 AM
Midgetville Norf Kacolacky
If it says k095 it will fit the 359
lilbenny
New OPE Member
4:35 AM
Something to be aware of, I would think that bar is 3/8lp, not regular 3/8 that your 359 is most likely set up for...
Yes it is lo pro. Ive been debating on spending that kind of money on a lo pro setup. Would rather have tru 3/8. Anyone ever have experience with the lo pro?
ny15
4:35 AM
Lima NY
if your looking for a light weight bar there are better ones out there than the Tech Lite in my opinion. You would have to change the nose on it to run standard 3/8.
concretegrazer
3:35 AM
Mo
Just go true 3/8.
There is something different in the bar mount on the tophandles. I can't remember what now. I altered this stihl bar to fit a 338 and had to change it more to fit the 346.
Couldnt I just run a standard 3/8 chain on that bar?
No
I wouldn't bother with a 16" lightweight on a 359.
lilbenny
New OPE Member
4:35 AM
Just go true 3/8.
No
I wouldn't bother with a 16" lightweight on a 359.[/QUOTE
Just go true 3/8.
No
Thanks for the reply man, info and advice. What other options do I have? Ill prob just end up getting a Husqvarna bar
concretegrazer
3:35 AM
Mo
That one will work. They should be easy to find. Oregon has them in the pro light & powermatch, husqvarna branded, ect. Check with @fordf150 or @Spike60 I'm sure they can help you out.
Homelite410
3:35 AM
Belle Plaine
May I ask, why a 16" on a 60cc saw? I run 18 as my shortest on my 2152.
KenJax Tree
¯\_(ツ)_/¯
4:35 AM
Over there
That bar is an A095 not a K095, that is a misprint. it's got a smaller tail than a K095.
lilbenny
New OPE Member
4:35 AM
Thanks guys...appreciate the replys. I did some more searching and decided on a carlton 16" 3/8 .058 bar from baileys, got loop of 38rc to try as well. Just adding a 16" bar for small stuff, and fun, never got to try one yet on the 359
