Maintenance Chief
- 8:45 PM
- Jan 4, 2020
- South Carolina
I decided not to do fingers in the end.Are you prepping for fingers or just bridges? Be mindful of pin locales.
You should rethink on that. These bigger bores like the added transfer.I decided not to do fingers in the end.
My index finger fits in them after opening them up, but maybe after I get a right angle maybe I'll give that a go.You should rethink on that. These bigger bores like the added transfer.
I considered it, but after running it this morning (even with the problems) I don't think I'll need any more flow . It was surprisingly snappy, with 2and1/4 turns on the high.I put my fingers in with a straight shaft
Yeah it was probably installed backwards from the get go so it never grabbed the crankshaft enough to score it.That clutch looks destroyed. Crank snout looks good?
You know it was to hot to be cutting fire wood today.Still needs a little more tuning and a long bar. I was pretty winded from flooding it.
