090 clone porting and building.
smokey7
4:02 PM
Detroit
Man that's a very odd shaped combustion chamber. Is that a kit cylinder or anyway or something
srcarr52
4:02 PM
Iowa City
images
smokey7
4:02 PM
Detroit
Both those gaskets look to have lines on them showing they were installed correctly at some point in their life.
Maintenance Chief
4:02 PM
South Carolina
That is true, but I received 2 broken rings 58mm with the saw ,and the intake side of the new piston had scuff marks on it ? Like someone was trying to run it without rings?
Maintenance Chief
4:02 PM
South Carolina
I initially measured the squish to .065 and that seemed a little bit excessive for the possibility of a good build for pulling a long bar with Authority. 20211121_182142.jpg
So I was pleasantly surprised to find a respected and generous porter with the tools and the skills to take .040 off the base and sleeve.
Maintenance Chief
4:02 PM
South Carolina
After rereading the entire exhaust port thread this morning I started to ponder the shortcomings of the 090 exhaust. 20211121_182101.jpg
I marked the piston skirt width, lots of room to grow.20211121_182037.jpg This is the port marked on the piston at TDC . I honestly don't have it carefully scribed out with an awl but with the kind of real estate I'm looking at I think ruffed in is ok.o_O
Maintenance Chief
4:02 PM
South Carolina
So I originally thought about fingers going up towards the intake but I'm not sure what my capabilities are? I think it might be better for me to start by putting in a connector between the top/bottom. Also giving the bottom port some length and width.
The actual port casting on the outside of the cylinder doesn't allow for too much insanity but I'd definitely like to give the more volume. 20211121_182118.jpg
Maintenance Chief
4:02 PM
South Carolina
I'm not totally sure how long it'll take me to get a runner up and going but Ill try to shoot for before Christmas.
Maintenance Chief
4:02 PM
South Carolina
Basically left the uppers untouched because I wanted to increase the amount of volume that could be ingested into the ports but I'm not sure if I hogged out the uppers if that would make it lazy?
