084 crank seal broken
treesmith
Tree Hugger/Cutterer
5:37 PM
Straya
G'day all, got an 084 which failed a pressure/vac test, anyway, found the clutch side seal was broken and had signs of the oil pump wheel rubbing on it, anyone seen this before?
jacob j.
Only the weird
12:37 AM
Coastal Oregon
I've never seen that before- there's a "cover' which the outer lip of that oil pump drive gear rides in (and keeps it set at the right depth)- maybe it was missing or worn down?
treesmith
5:37 PM
Straya
Thanks Jacob, there's nothing else.
It was clutch then large washer cover then oil pump wheel then seal.
treesmith
5:37 PM
Straya
I priced up parts from stihl dealer in Australia
Two seals, two bearings, two rings, fuel, impulse, intake boot, case gasket and a carb kit for an 084
$580au
VinceGU05
one day when i grow up...
3:37 AM
S.E Australia
13 bucks small seal 18 for big seal 5 bucks flywheel bearing. 40 bucks clutch side bearing( I got heaps of them both). Rings, get them from the Greek. Impulse and fuel lines can be normal hose or molded ones would roughly 20 each. 25 for carby kit and intake boot at a guess 60 from Stihl.
I might even have a spare set of rings. And case gasket 5 bucks. I can show you the invoice [emoji6]
jacob j.
Only the weird
12:37 AM
Coastal Oregon
Yeah, it looks like you're missing part #1 in Vince's diagram. That cover keeps the worm gear at the appropriate level.
treesmith
5:37 PM
Straya
Which dealer Andy?
G'day Sandy, from Cannings, Melbourne.
Can get slightly cheaper elsewhere but they get stuff quick and knock off 10% which almost helps :)
treesmith
5:37 PM
Straya
Sweet, cheers Vince, yeah, intake boot is $92 from cannings
Prices are insane
Savage Saws
kangawallaroo!
5:37 PM
Cockatoo, Australia
Only really insane from Cannings mate. They're a dam good business but, they have big overheads, staff etc and need to make a profit. Alot of people in the arborculture industry in melbourne use Cannings because they're quick but curse them behind their back for being so bloody expensive! Alpine mowers in Monbulk or Stihl Ferntree gully are great to deal with and not silly expensive. If you ever need O.E.M stihl parts let me know, i buy a metric ton and get a good dicount.
treesmith
5:37 PM
Straya
I've bought a few things from Ferntree Gully stihl, I may pay them a visit tomorrow
VinceGU05
3:37 AM
S.E Australia
So they selling you a piston with those rings ? Can't see any other reason to be so much.
