075 Decomp Valve Substitute
TPA1
OPE Member
7:59 AM
Texas
I got over 180PSI on my 075, and I need my decomp cause I'm a weenie.
The mounting hole is offset from the cylinder, so I don't have to worry about clearance issues with the piston. I ordered a genuine OEM valve, but I find that it doesn't reseat well and can be leaky.
Is there one that can be adapted from a different model (same threads)? One from a more modern saw that doesn't cost an arm and a leg?
Chainsaw Jim
Con Artist LLC
5:59 AM
Springfield Oregon
I had the same problem with the new valve they sell.
I believe you can use a washer that fits down in the bottom of the threads to get the seal air tight. I didn't have the right size washer on hand so I just plugged it permanently.
