046 what year
5:21 PM
Very nice. I've tried to acquire one several times, but it never happened.
Once, the guy told me it was mine, then sold it before I got there, and another time I bought one that was all apart only to find out the jug had been replaced.
pbillyi69
2:21 PM
USA
so does that mean that you dont have an 046 at all?
EAK044
4:21 PM
Wausau
I've got a few of the early 044 Zama carbs w/o the snorkel. Some are labeled Japan, some Hong Kong.
I believe the one on my beloved 044 is Hong Kong. I did rebuild it once years ago.
What is the reason for the snorkel? Will a snorkel C3M work on a saw that didn’t have a snorkel C3M?
5:21 PM
The snorkel is supposed to adjust the carb (slightly) when your air filter gets dirty. The plastic piece that goes over the carb did not have an oblong cone for a snorkel on the early 044s. My 044 has the cone, but it is closed. Later 044s and 440s have the cone and it opens into the snorkel.
I guess if your air filter is dirty, it moves the diaphragm a bit.
You can run either carb on either saw, just if the carb does not have a snorkel, make sure the cone is plugged, or vice versa (plug the snorkel).
Welcome to the site!
EAK044
4:21 PM
Wausau
Thanks!
I have a C3M carb on my 044 non snorkel and I just can seem to figure out what’s wrong with it. I put a rebuild kit in it and it got a little better but I still can’t get it to tune. Thinking it might be something with the saw, I robbed a carb off my other 044 and it tuned and ran perfect.
Got any suggestions on what I should check?
5:21 PM
If it ran perfectly with the other carb, then it is not the saw.
Maybe some dirt is still trapped in there. I would take it apart and blow compressed air through all the openings.
Also, make sure the lever valve is set correctly, that can screw things up.
