036 oiler nightmare
1:10 AM
I have never had a bad pump. The ones I’ve seen had seriously deformed lines, melted lines, that leaked like a sieve.
Me neither. I think the only way one could go bad is if it was run awhile without oil. There just isn't much to go wrong in there
Stihlsmoking
City Hillbilly
1:10 AM
Cincy
After 3 pages I gotta say. LMAO
These oil lines are damn simple if you just follow the instructions provided with the kit.
Yes I did one on my 034 and almost got it by hand used a hair dryer to get last 1/4 “ of hose on Oiler barb ? Wasn’t that bad.
Stihlsmoking
City Hillbilly
1:10 AM
Cincy
The only broken one that I’ve seen was worn through by using the wrong clutch and incorrect washer. There’s not much inside of them. I guess the “teeth” could break or wear out too.
This is the only bad one I’ve seen but dont know what caused it?
I assumed it good till I tried turning it ? Replaced it and used proper washer and good to go no washer on disassemble!!
Stihlsmoking
City Hillbilly
1:10 AM
Cincy
55DF9781-5A96-4189-88E4-D724F4E5B6ED.jpeg Front looked ugly ? And I like to rotate with fingernail this one didn’t turn ? If course it was nasty so I cleaned it removed it and found it locked up ? Upon closer inspection you can see crack on lower bolt hole ?
Backtroller
12:10 AM
Land of Badgers
I can see why that piston broke. Something must have been rattling around in there beating the hell out of it.
Looks like you need a new one. I heard to stay away from the aftermarket versions.
Stihlsmoking
City Hillbilly
1:10 AM
Cincy
It’s been replaced since. working fine. No after market here not on those parts. Lol. Good used oem Oiler on her now.
angelo c
Coal Member
1:10 AM
I'm glad the thread got everyone busy and motivated! Sure got @angelo c and @Stihlsmoking off their butts!
:risas3:
It would definatly take longer to drill the needle nose pliers then to boil a pot of water, screw the oiler in and gently push it home. I'll try the nail trick next time for chits and giggles though.
