Clarkc9743
- 11:08 AM
- Sep 29, 2021
- Mt Vernon, IL
Few weeks ago I ran across a 036/044 hybrid build using just the cylinder seemed interesting but alot of work. I did like the idea alot though.
Long story short I found a 034av with plenty of good parts came with a 034 super I bought. Plan was to sell the super and build the other. I have 044 slant fin with 10mm case I got for cheap a long time ago with bad crank bearings.
I'm always trying to find the lightest thing possible with power so I did some looking and checking and this is what I found. The 044 uses the same bearings, the flywheels are the same tapor however the 044 is about .190 larger. So no using a poly wheel unfortunately. The crank (one without a piston)actually looks pretty much identical aswell just much longer stroke. The crank even fits in the 44 case as is but barely rubs.
So where I'm at now is I'm waiting on a meteor 044 10mm piston. A boring bar for my mill to clearance the cases about .060-.070 just to have plenty of room and keep volume similar as before. And various odds and ends like the carb, and a better filter setup like on the 044. But this could be pretty interesting.
I wished I had a 12mm crank just to see if it would fit because even though a big bore is frowned upon I'm sure it would have a little more potential than normal 044 setup. But regardless will be a very light weight saw to use with a 25" Stihl light bar.
