026 worth $100?
Stihlsmoking
City Hillbilly
2:36 PM
Cincy
Thanks fellas. First time being this deep in a saw. Trying to learn as I go. Didn't realize the pins moved. I will try to get it apart Tuesday without pulling out the BFH. Wanting to get everything apart and cleaned up well. I have a small list started already. Would I be better off replacing the fuel line, impulse line, oil pump/driver, and intake boot? Aftermarket or OEM P&C? Rings?
OEM is better imho guess it depends what you want to spend ?
stihl_head1982
Here long time
2:36 PM
USA
If you're going through the saw count the fuel line, filter and impulse line as simply part of the process. As for the oil pump and driver -- it is unlikely that it will need replacing. The oil line however, may need replacing -- they can be a pain sometimes to remove from the case. (Last one I bought at my dealer cost $3.00 plus tax). I'd try to clean up the cylinder. Mastermind has a thread which shows a viable method -- works great! I'd put a Meteor piston in it. For the quality and price you can't beat it. I also use the thin gasket for the cylinder (Stihl Part #1118-029-2306). My recommendation is to replace the needle cage bearing as well with an OEM bearing. (Too much trouble with aftermarket needle cages at this point). Keep us posted on the progress.
Dustin4185
2:36 PM
East TN
I was going to try to clean it up first and see where it goes. How does that oil line come out/off? It pushed through to the bar side, but I can't seem to get it through going the way it needs to without cutting the brass piece inside off.
stihl_head1982
Here long time
2:36 PM
USA
pull it out from the front by the brass piece.
