baddboyy21
Active OPE Member
- 5:39 AM
- Jul 9, 2016
- Pittsburgh, PA
I'm rebuilding another 026. I've replaced the seals. I did a vacuum leak test and it takes two minutes, 50 seconds for the the gauge to go from 10 down to 5. According to the service manual, if it holds vacuum for 20 seconds you are good? I assume my test is acceptable? I could not find an actual leak anywhere.
