Chainsaw Jim
Con Artist LLC
- 6:34 PM
- Feb 8, 2016
- Springfield Oregon
.325 pitch, .050 gaugeWhat chain is that? .325?
I'd like to see thatIf an ms180 can be built to smoke 200t's then I suppose it is theoretically possible.
Jack up the ignition timing 4-6 degrees and run it again. You need softer wood for sure to get it loaded down. Wider chain maybe?I figured this would put the intake in check..
Another stock cylinder to show size difference for others who might be interested..
I put a filter on it and re-tuned to see what's up with it. The 290 filter sits nice and level, but the cover won't fit. One from an 044 looks like it can be modded up to fit and look halfway decent.
View attachment 115021 View attachment 115022
That filter is one funny looking sumbitch, LOL. I think, with a little luck, the 044 cover might resemble a max flow on an 046.
It may not win any races, but it sure is such a simple saw to mod that it makes it a little fun to do.
I wish I had some better race quality wood to play with, this stuff I'm cutting is half petrified from dead stand curing.
You might. Have one out of many 017-180's that ran better than most. Saved it to the shelf when the seals were going away.I'd like to see that
Mini, small or standard rim?I see a pro 11 pin for .325 chain, but might need a fatter bar for that, so one step at a time.
I watched a 180 take on the winner of a 200t shootout a couple years ago. The 180 mopped the floor. There were about a half a dozen do-overs and the outcome never changed. My camera took a dump on me or it would be on video.I'd like to see that
The chain is for a smaller race saw. I didn't have anything small enough to run that chain for testing so I built this 025 for that purpose. LolJack up the ignition timing 4-6 degrees and run it again. You need softer wood for sure to get it loaded down. Wider chain maybe?
Toss a 029 carb on it.The chain is for a smaller race saw. I didn't have anything small enough to run that chain for testing so I built this 025 for that purpose. Lol
It's over carbed right now. That 461 carb is hogged out and has been sitting on my bench for a while now waiting to go on my 461. I grabbed it instead of taking the extra time to set up another HD carb. I'm going to swap that out sometime soon.
