Lightning Performance
- 10:41 AM
- Jan 26, 2016
- East of Philly
Continue
There AV sucks IMO. They don't bring much. Rebuilt many 025/250's. They do good with a muff mod, sure. The Raisman jugs out run the factory ones witch is not the norm. More compression and better timing to start. They port OK. OEM ports better. More meat in the casting.I will say for a beater cheap saw... an 025 isnt bad. I almost enjoy them....ALMOST.
Muffler mod, switch to 3/8LP and leave them alone. Race saws they are not.
Sent from my SM-G920V using Tapatalk
Treemonkey has the recipe for the ms250 that'll wow ya..If an ms180 can be built to smoke 200t's then I suppose it is theoretically possible.
Lol, yeah he had a rough dayIndeed...
Like it don't matter if ya got the fastest damn 365 around, if that mf'er won't start in the finals...
Still lol'ing about that one.
Sure was a lot of fast saws there.
Hell, my 365 wasn't even in the top 3 as far as power that day..Lol, yeah he had a rough day
If i build one and toss it in the truck...never lasts more than a week at $125-150There AV sucks IMO. They don't bring much. Rebuilt many 025/250's. They do good with a muff mod, sure. The Raisman jugs out run the factory ones witch is not the norm. More compression and better timing to start. They port OK. OEM ports better. More meat in the casting.
I suppose it depends on which cylinder is used. I have two 42.5mm cylinders sitting in front of me, one has double transfer channels with 20° blowdown while the other has quads with 32° blowdown. Both have same exhaust with intake opening being one degree higher on the quad cylinder.Treemonkey has the recipe for the ms250 that'll wow ya..
The stock timing #'s are pretty racey already.
It's a matter of carbing it to feed the little monster.
What jug do you think is better Jim?I suppose it depends on which cylinder is used. I have two 42.5mm cylinders sitting in front of me, one has double transfer channels with 20° blowdown while the other has quads with 32° blowdown. Both have same exhaust with intake opening being one degree higher on the quad cylinder.
Out of the box I'm assuming the one with 20° BD. I put one together not too long ago with the 20° and it was a real impressive runner. I can only assume because a couple other "so so" runners I've experienced may or may not have had the other cylinder..I never thought of checking at the time.What jug do you think is better Jim?
I doubt Scott will chime in with any tips.
Seems few of these have been built.
I'd imagine you have to trim the skirts to miss the crank if they are much longerI noticed a way to boost compression using a 44mm husky 350 piston, where the pin to crown height is taller by 1mm. The ring pin lands above the intake at bdc, the skirt is 1.95mm deeper, and I believe it has enough meat around the skirts for the OD to be machined down to the right size.
I think it might be better than going two piece head because the longer skirt makes it possible to enlarge the intake nearly twice the size to accommodate a larger carb.
That was the last thing I checked before mentioning it. It looks like the inside edge may need beveled a little bit. Even if it does need trimmed it shouldn't be enough to throw it out of whack.I'd imagine you have to trim the skirts to miss the crank if they are much longer
What chain is that? .325?It still needs a v-stack and clutch side cover, but I'd say it isn't a bad start. I haven't tried boosting compression with a different piston or pop up yet.
The intake was pulling too much sawdust in for doing down cuts.
