Junk Meister
- 12:45 PM
- Aug 10, 2016
- Nebraska
If You want to ISOLATE the problem Put a Jack against the cylinder and it should hold -not leak back from internal bypass - if you think it is the valve tie the retract port to the extend port with a hydraulic hose or put a plug on both inlet ports of cylinder with, cylinders still full of oil then jack between the platen and wedge.. when the cylinder creeps ... from jack pressure let us know.. this will be the cheapest way to pinpoint or eliminate the cylinder bypassing.
