Chainsaw Jim
Con Artist LLC
- 4:31 PM
- Feb 8, 2016
- Springfield Oregon
Wonder how thick the crown is at the edge of the popupDoes this crap?
View attachment 152582 View attachment 152583
Lol. 394 piston hacked up to fit a 660 big bore without freeporting.
How long until it goes "kaboom!"?
Neve know until you try it!Does this crap?
Seems like enough. I hope it works for ya.The sides and back are still pretty decent, but it's the front that has me concerned. I marked the spot where it is 2mm thick. It's a pretty small spot so maybe it'll fly. View attachment 152620 View attachment 152621
The sides and back are still pretty decent, but it's the front that has me concerned. I marked the spot where it is 2mm thick. It's a pretty small spot so maybe it'll fly. View attachment 152620 View attachment 152621[/QUOTE
2mm is pretty thick, i have ran a pop up that had ,.070 at the ring land, it’s held up!
I wish the cylinder had better plating. It needs some big fingers and whatnot, but it may not take it. I suppose if it runs well enough it'll be worth sending off to us chrome.Seems like enough. I hope it works for ya.
How do you account for different wrist pin diameters?I wish the cylinder had better plating. It needs some big fingers and whatnot, but it may not take it. I suppose if it runs well enough it'll be worth sending off to us chrome.
I need to get a few saws done before I can get back to this one.
A 395 bearing allows the 13mm pin to fit into a 660. It’s thinner.How do you account for different wrist pin diameters?
The rod ends are the same diameter on both saws. 13mm thin bearing, 12mm thick bearing. 395 piston on the 660 is plug and play, the 660 piston on the 395 would require clearancing to fit the wider rod end. There's no need for spacers with the 395 on the 660 because the cylinder holds everything centered.How do you account for different wrist pin diameters?
Spacers are used to hold the rod straight, not center the piston. Once that wrist pin bearing wears a little the rod gets more lateral movementThe rod ends are the same diameter on both saws. 13mm thin bearing, 12mm thick bearing. 395 piston on the 660 is plug and play, the 660 piston on the 395 would require clearancing to fit the wider rod end. There's no need for spacers with the 395 on the 660 because the cylinder holds everything centered.
Dammit Billy! You made me get up to go back out in the shop to take a look.Spacers are used to hold the rod straight, not center the piston. Once that wrist pin bearing wears a little the rod gets more lateral movement
