Jeffbecky1
- 12:31 AM
- Jan 28, 2017
- Scott County, Kentucky
I’m new to these computerized carb saws and was wondering what fuel mix ratio best for M-tronic saws
This is a slippery.Not sure about "best" but I believe the general consensus is 40:1.
P.S. Please don't ask which oil..
That's what I run at 40:1, coats everything nicely and leaves very little carbon behind.I’m going to be running Bel-ray H1-R I’ve heard good things about this oil, I believe Mastermind runs this oil
I guess he switchedMy Mastermind 661 has a 40:1 only sticker on it that was put on there by Randy and he runs yamalube 2r if I'm not mistaken.
Run whatever you normally run unless you have a problem with it.
H1R Belray or Hondas best, about the same oil, are good to best out there. I tested lots of it in stuff and saws. Very low wear but like Mike said.....you better get it hot or your muffler will weep goo.I’m going to be running Bel-ray H1-R I’ve heard good things about this oil, I believe Mastermind runs this oil
That’s only if using stihl oil do they specify 50:1. It says if using any other oil to run it at 25:1Most Stihl manuals will specify a 50:1 mix, I don't know what "best" is though
