Manofstihl661
- 12:44 PM
- Nov 30, 2016
- Texas
Unfortunately caliper isn’t working. Have to get a new one.
Then there is the spark plug electrode no one considers.But yes i know what you are saying measure theI’ll check mine in the morning. If I remember right it’s right at the tip of mine. Definitely the more you shrink the cc size of the chamber the higher your numbers should be. Measure the plug from the end of the threads to the gasket and try to get your hose to match that.
Schrader depth when you get time. Do you have a 10mm set up?
Cant tell
Best I can do for a valve comparison currently lol
I will take one out of a good working 14 mm adapter hows that?The Schrader valve should be white I believe. There is very little spring tension in them. Try one from a tire...it should read 50 psi or so lower. If it reads similar to your other valve, I'd bet the valve is bad
You might have saved me a lot of money ,time and trouble friend. This got by me because it was a brand new Snap On part. Boys I think its solved!The Schrader valve should be white I believe. There is very little spring tension in them. Try one from a tire...it should read 50 psi or so lower. If it reads similar to your other valve, I'd bet the valve is bad
Simple stuff can be overlooked because you overthink it.Glad it was simple.
YepI will take one out of a good working 14 mm adapter hows that?
So what is the black for?Haha I had a good thought lol. Yeh they make different resistances and such for different applications
I'm sure there are other places, but the only one I know of that can get them are NAPA. Don't order the bargain ones off ebay. None of them work, even though they're whiteYou might have saved me a lot of money ,time and trouble friend. This got by me because it was a brand new Snap On part. Boys I think its solved!
Snap On maybe or Napa thats all I can think of.I'm sure there are other places, but the only one I know of that can get them are NAPA. Don't order the bargain ones off ebay. None of them work, even though they're white
