RIDE-RED 350r
- 2:29 PM
- Feb 8, 2016
- Blossvale NY
True..but I still think the port layout on your new KS is going to be very similar to the Mahle
If it’s not it will beTrue..but I still think the port layout on your new KS is going to be very similar to the Mahle
Soon?If it’s not it will be
Hopefully, I have to get some big stuff done around here then I intend to pull the topend...finally.Soon?
It's entirely possible. Look on the base if the cylinder, it will say Mahle or KSI didn't even check mine when I did the base gasket delete and put the new ring in. But I do know that squish was as low as 15 thou without the gasket. I made up a coke can gasket to get me to 18.5. Would that indicate Mahle cylinder?
Have to check. Had her out today cutting some white and yellow box. Compression is definitely starting to come up with the new ring breaking in. And it just wants to rev too!! I've got it tuned way rich still and it pulls 13500 with ease. I don't really know how high to let her go when fully broken in, but I would imagine north of 14000 would be a breeze for this saw. If I even slightly relax the pressure currently it just four strokes hard.It's entirely possible. Look on the base if the cylinder, it will say Mahle or KS
That is a badass pair of saws Dale...very niceThis is my only current 288 pic. Along with my 266. Dad gave me both.View attachment 114027
Good deal glad to see this back going again.Well I received the Mahle cylinder from Rattler that he cut the base and band for me the other day (thanks bud!) and finally got some time to get this project back on the rails today.
Swapped in the crank that Daserlon sent (another tip of that hat Dale) and got the bottom end back together. Everything went pretty smooth and I got started with the porting of the cylinder getting the exhaust port done except for the final finishing bringing it to 98 deg and widening it a bit. Squish with no gasket came in right where Rattler wanted, bout .022"-.023" doing the quick check method through the spark plug hole. He got .0215-.022 on his setup cases and I'm sure that's what I would get if I did the 4-point method. All is well in that area. Kudos to Mike for a job very well done!
Planning to work on it some more tomorrow after work. Going to go after the transfers, looking to flatten them and bring them up to about 118 from the 120/124 they currently sit at with the tapered opening. Only took a couple of pics today.
It's like deja Vu all over again! Lol!View attachment 115787 View attachment 115788
Hopefully you get a little break from all the storms. Looking forward to seeing this done, and how it compares to the ks cylinder.Yeah, we've had old man winter show back up here over the last week or two. If we weren't dealing with the noreasters, it kept snowing an inch or two overnight prompting that 2:45am phone call to go to work early. Lots of OT!
Joe you are very Welcome my Friend anytime and also glad to see this thread back can't wait to see her runWell I received the Mahle cylinder from Rattler that he cut the base and band for me the other day (thanks bud!) and finally got some time to get this project back on the rails today.
