Wonkydonkey
Plastic member
- 7:49 PM
- May 14, 2017
- Sussex, UK.
Guess I should have added a winky smiley. It is called the 'safety corner' method. Steep face, narrow hinge and always bore in leaving a post of holding wood in the back so that the tree can't take off before the cutter is ready or sit back before they have got a wedge in.
When I was learning, not that long a go we had 3 or 4 cuts to learn. All except one had a 50\60* face cut with a nice clean fit (no Dutchman) the back cuts were straight backcut, split level for a slightly leaning tree. And a danish default (aka danish pie/ safe corner) which was for a tree leaning any way and where you may only have one escape route, it was that you can set you hinge and then pull the trigger on the safe corner when you were ready.
This danish cut was my fav.
The other cut was for a heavy leaning trees. And you did two face cuts at 25\30* each side of the direction you wanted to fell, then you cut straight into the back (so you now made the tree into a triangle which was being reduced) the end result was to reduce the chance of a b-chair.
I think but not sure if this cut is also called coos bay cut, I was trying to figure it out the other day. But discriptions are hard to sometimes understand.
