PogoInTheWoods
- 2:54 PM
- Apr 23, 2016
- Ohio
029/MS290, MS310, 039/MS390, 034/036 (with the smaller 13mm needle cage) will interchange. 031 is a whole different saw and wasn't part of the 1127 '0' series. 034/036 (1125 series) used the same sized setup until beefing up the needle cage due to failures.
Rim drive kits are available to convert from a spur. 1125-007-1002 is the part number and includes the drum, 3/8-7T rim, washer, and 'e' clip. 'Bout 30 bux. A .325 rim can be substituted if you're dealer has a clue and is cooperative. An Oregon alternative is 34162x and is about 20 bux. May or may not include the washer and clip depending on source. Both use small spline (sm7) drums and obviously the small spline rims. Neither kit includes the needle cage. Replacement / spare rims are around 6 bux a pop.
