Chief Cat Herder
7:48 AM
Awesome, thanks! Tried to clean up the casting imperfections on the transfers, were some odd spots that i didnt like, same with the intake...still need to polish the exhaust as well, its a pretty rough cast port...LOL anything glaring i need to touch up? I have plenty of time as i am waiting on a new intake boot....
Looks great.
bogieboy
8:48 AM
Rochester, NY
@Mastermind this look about right for a cross/MMSW 661 with that 21 thou squish? Is about 180 with the compression release pushed... also, no intake boot yet, just open port
bogieboy
8:48 AM
Rochester, NY
I didn't expect it to be that high......but it will be good there.
I didnt either!!! I read thru the thread where you developed these, and if i recall it came out about 180...
I just checked my comp gauge with the shop air that is set to 90psig, and it read 100 psi, so i guess my measurements are about 10psi off comparing to a second gauge, still... thats 200 psi...LOL
Chief Cat Herder
7:48 AM
To be fair.....the Chinese don't seem to be capable of getting anything right.
Maintenance Chief
8:48 AM
South Carolina
Started out as a scrapyard find, but thanks to @Woodslasher for one of the felling spikes and @Duke Thieroff for a pop up piston, air filter cover, and full wrap handle , it will murder trees once again!
I used the OEM cylinder and case/crank, and a Bing 49 carburetor, unfortunately the tank couldn't be saved.
Ended up with .023 squish with a metal base gasket and the Dukes piston.
I have to put a new air filter and clutch drum on it before it cuts.
I did fire it up, it definitely sounds strong.
mirage
6:48 AM
idaho
Can anyone tell me the model number of this saw? I need to replace the seals in it and need to order the right ones.
LandFakers
8:48 AM
CT
View attachment 403220View attachment 403221View attachment 403222View attachment 403223
Nice rebuild, looks great!
bogieboy
8:48 AM
Rochester, NY
Nice! That 660 is cleaner than the 661 i am building...LOL somehow mine has paint spatter all over it from the previous owner...20240106_210407.jpg
bogieboy
8:48 AM
Rochester, NY
Pretty sure i know the answer to this, but i will ask anyways....
This cylinder is toast right? The skirt damage you cant grab with a fingernail or pick, but the wrist pin scrapes are fairly deep....
Chief Cat Herder
7:48 AM
It will run. The important part is the area above the ports. Clean up the bevels with some 220 grit.....and try it.
bogieboy
8:48 AM
Rochester, NY
I have no need to, was just curious, this is the cyl out of the ms661 that i put the Cross/MMWS cyl and piston on... there is a pretty good ding above the transfers as well from the wrist pin, that pic was also after a quick hone with a brake cyl hone...
Chief Cat Herder
7:48 AM
I've used worse to get a saw back in service. Sorta figure it would be a short term fix.....but in most cases they keep on keepin on.
bogieboy
8:48 AM
Rochester, NY
Question for the collective, if given the option, would you rather have an early (1114 series) 020t, or an ms201tc-m, and why you would prefer said saw? If it matters i am too old and fat to climb, so usage would be a limbing saw...
Loony661
Stock chainsaws suck.
7:48 AM
Winona County, MN
My honest opinion is that if you’re not aloft with it, get a rear handle saw.
bogieboy
8:48 AM
Rochester, NY
I have limbed with both, abd for some reason, i prefer the smaller formfactor of the top handle for that, but looking for a lighter, more powerful saw than my poulan 1800....LOL
Side question, given the ground limbing question, what rear handle would you recommend for the task?
Note that i already have an ms170, ms280, 044, and ms661 in the stihl lineup, as well as a mac 1-10, and a JD cs46, alongside the poulan 1800...
