old_sir_henry
- 3:52 PM
- Nov 9, 2018
WTF ???
Easy, just spin the chain backward fast enough!How did you get the engine to run in reverse?
Now, hand me back my beer and open another!WTF ???
I would have thought the timing for spark would be off?Easy, just spin the chain backward fast enough!
Yes, that's what I did.I would have thought the timing for spark would be off?
The simplest way would be to reverse the video....
Okay, that's a good one! Makes for a head scratcher!Yes, that's what I did.
I used a Zemeckis Cube and recorded time turning back.
Maybe I installed a two way electric starter in my PS-5105...Okay, that's a good one! Makes for a head scratcher!
My Rotax engine in my snowmobile can run forward or reverse. It has two pickups on it though. One for forward rotation and one for reverse rotation.
Ne need for a gear box to back up.
I'd guess dirt through the intake.Ah, that makes sense...
The spark plug was loosely installed, so maybe it was sucking in dust? The cylinder looked to be in stock form.
Super helpful, thank you! I'll check on the air filter and elbow when I get home. Last thing I want is to burn up the saw with a new piston.Never really had an issue with dust ingress on that series of saws, I always slip an rubber 'o' ring over the air filter snout anyway on any saw that has just a slip fit. I also had a 5105 that somebody had over tightened the plastic elbow between the air filter and carb and distorted it, just put a slither of RTV or make a gasket. To check for any leaks just spray with brake cleaner around the inlet when running, it will drop revs if leaking. Also check that the air filter either has the foam gasket ring on top of the carb or no hole in the air filter where it touches the carb.
Should this model saw be utilized for bucking up this size of logs?
No!
Can she handle it though?
Yes!
Dolmar PS-4600 Speed, .325" 64DL semi chisel Husqvarna, in Turkey Oak
View attachment 413348 View attachment 413349
Chicken & duck bedding, plant/flower bedding.What do you do with your Sawdust?
