eric4
- 5:20 AM
- Dec 23, 2021
- Northern CA
Never really had an issue with dust ingress on that series of saws, I always slip an rubber 'o' ring over the air filter snout anyway on any saw that has just a slip fit. I also had a 5105 that somebody had over tightened the plastic elbow between the air filter and carb and distorted it, just put a slither of RTV or make a gasket. To check for any leaks just spray with brake cleaner around the inlet when running, it will drop revs if leaking. Also check that the air filter either has the foam gasket ring on top of the carb or no hole in the air filter where it touches the carb.
Looks like mine has the foam gasket on top of the carb, and the hole in the air filter. The foam ring has deteriorated quite a bit though, and doesn't seem like it'd be a tight fit.
How would you resolve this?
Also, here's a shot of the intake side of the piston...
Cheers!
