KS Plainsman
- 3:17 PM
- Aug 7, 2019
- Kansas
I was disappointed with the CBN wheels I tried. Got coarse results, was still able to overheat cutters, and little support from the vendor. Might have been the specific wheels I got (‘Diamond’ brand). I assume that they can be made with different size / grades of grit. Advantages were minimal grinding dust, and a constant shape.
Standard ‘vitrified’ grinding wheels (aluminum oxide, silicon carbide, ceramic, etc. grit) need occasional dressing, and can be custom shaped, but generate a lot more dust (I grind outside when I can).
The color is dye to indicate grit size, grit type, type of bond, etc.: things that determine how fast they will remove metal, how coarse or fine they will cut, how fast the wheels will wear, etc.
Most basic ‘pink’ wheels work fine for most users. Different grits, etc., can give you more options, if interested.
ArchrrPlus said more of the white wheels are on the way. I am waiting for a 1/8” and 3/16” wheel to compare against the ones I have.
Philbert
As in Diamond Wheel Inc.? Those are the CBN wheels I got, that I have yet to try.
