Stihl special tool identification
RipRap
3:43 AM
Virginia
The tool that looks like a threaded bolt has a pin that goes through the top, looks like it might act as a depth gauge???
Any ideas as to what it is?
Thanks
DND 9000
9:43 AM
Germany
Could be a test flange. Do you have a part number for that?
RipRap
3:43 AM
Virginia
No, both those tools came in an incomplete tool kit #0000-890-1705.
nohoff
professional flusher
9:43 AM
Germany
the left one is a test flange.
The screw has left headed threads?
RipRap
3:43 AM
Virginia
No, it's right hand threaded. The square flange is definitely for an old piece of equipment.
backhoelover
SERVICE MANUAL MASTER
3:43 AM
lincolnton nc
the boltoks like it is for the ts wheel bearing assembly run out plate with is use with the older stihl ignition timing kit.
backhoelover
3:43 AM
lincolnton nc
im pretty sure about the flange but dont hold me to it on the bolt lol
RipRap
3:43 AM
Virginia
Here's a photo of the set I got off ebay 0000-890-1705. I live about 4 miles from the factory in VA.Beach. None of the dealers here know what it is.
backhoelover
3:43 AM
lincolnton nc
that tool kit is in the stihl 1985 tool manual i have it in paper but dont have it in pdf. the flange you got is from tool kit 0000 890 1710. the flange is part number 1119-850-4200. its used on the 038 saws
backhoelover
3:43 AM
lincolnton nc
i could have swore that i make a copy of the 1985 to pfd. let me do some digging. if i did i know i would have sent it to @ray benson cover is orange with a wrench and nut
RipRap
3:43 AM
Virginia
Ok, I thought that the flange must have been from a while back. Have you ever been seen the other tool before?
backhoelover
3:43 AM
lincolnton nc
you can thank the super cool @Definitive Dave for this spead sheet. it should cover several of the seal and bearing installer in your kit
  • oil seal installer cheatsheet V1.2 2.19.16.pdf
