Wonkydonkey
Plastic member
- 7:58 AM
- May 14, 2017
- Sussex, UK.
I will add, when a chain is filed 1/2 to 2\3 and the normal depth gauge is used. It starts to cut thinner chips/dust. When I used the progressive gauge the chain cut like new.
or if a new chain is manicure with a progressive gauge , you get good results, if you don’t like it, after a few tooth filings you could just go back to the normal gauge,,but as said in the previous post try the hard setting first even in soft wood.
I really do like them.. I think it’s a try it and see if you like it.sort of.thing..
I have only used the hard setting, as we have hard wood of all hardnesses
as for bore cutting I don’t do it much When the chain is 2/3rds filed it kicked hard, it could be me but I noticed it more than a new chain
I gave my mate a saw to use, he seemed Impressed with it,, but wasn’t sure if it was the saw or the chain. It did cut good chips compared to his (I don’t need a depth gauge chain) I just give the rakers 2 licks on file till it cuts way of thinking.
I looked at his chips from his chain.. 1/2 was dust
only one way to find out test one with a progressive
