Nutball
- 3:19 AM
- Oct 31, 2018
- Mt. Juliet, TN
Good idea, I just hate the thought of taking the case apart after the trouble of putting it together, and I've never taken one apart before. I could try using a vacuum while grinding on the assembled case, it would be slow going keeping the rpm low so as not to throw shavings away from the vacuum.
The cylinder is still a ways off from fitting. It already looks tight, and still has to drop a lot more. I don't like how the bolt holes have turned out. I'm thinking I'll JB Weld the holes and redrill them with the hard part being keeping the drill straight cutting partially through hard aluminum and lots of soft epoxy. There isn't much room for the bolt heads to fit the new pattern with a 58mm bore. I'll have to make a nylon adapter of sorts to try to align a 660 gasket to mark the holes.
Looking ahead, I'll need .100" cut out of the squish band, and a little more than .060" off the top of the piston. I'll loose the top ring due to lost plating at the top of the cylinder. Would it be a good idea to drill little holes to put pressure behind the remaining ring?
