Stihl 441 magnum
My stihl 441 not oiling 20 inch bar very well
  • Poll choice
    Votes: 1 100.0%
  • Poll choices
    Votes: 1 100.0%
  • Total voters
    1
jason72
New OPE Member
4:33 PM
Iowa
Ive cleaned the tank. Shot compressed air through supply and vent. 20 inch bar smokes with oiler adjusted fully clockwise.
Frogfarmer
4:33 PM
Tang worn off of worm drive? Wrong drum that doesn't engage tang. My 441 oils a 25 just fine so it is capable if all is working.
Pincher
4:33 PM
sw corner of twin cities mn
Welcome Jason72. A little more information might be helpfull. Did it oil fine and quit? Is the saw new and never oiled correctly? Does it oil a different bar fine?
2manyhounds
4:33 PM
Minnesota
Need more info, mine will oil a 32 in dense wood not so much in the fuzzy stuff,so it's capable. Guessing it's the pickup or the worm gear wore
2manyhounds
4:33 PM
Minnesota
You getting things figured out with your saw?
Definitive Dave
Piss Rev Mafia Member
5:33 PM
Central Ohio
Dull chain?
Chain tension too tight?
Brake not fully disengaging?
5:33 PM
i had a bar like that and the tip was wore out
5:33 PM
nose spread open sprocket was on one side chain on the other putting a bind on the saw and added friction
