So what did you buy today
Partner
9:14 AM
Poland
I would leave this piston here for worse pistons, but the saws work
Partner
9:14 AM
Poland
A 25-year-old grinder Bosch for $10, a pre-GWS model. The engine is in much better condition than the housing 😉 I put on a half-inch larger cover and greased the bearing and gears. Green PWS models from this period did not have a spindle lock / See the dial attachment on the outer nut
legdelimber
3:14 AM
N.C.
Riddle for today 😉 what is it?
On the red cylinder/pump. I was looking at that sticker and noting the gas types.
Then looked at those chambers holding something looking like filter material (or ph~chem reactive media?)
Then I was left with thinking of some funky compressive firestarter, the hose looked a bit lightweight though.
Next was something the shop go-fer kid would be trying to turn into drug paraphernalia.
The thumbwheel sorta brings a bic lighter to mind. Is that a ratchet mechanism in it?
The last? uhmm, bits of something from the back pages of an old Hustler magazine.
Partner
9:14 AM
Poland
Yes, there are two filters and the ratchet mechanism rotates freely, so something is missing because there are 2 holes under the mechanizm. It only seems to suck in as if there was a non-return valve or it is damage / If you remove the filters, you can suck out the oil, e.g. from a lawn mower 😉 I picked it up as a curiosity for $2
Partner
9:14 AM
Poland
A 30-year-old Kress random orbital sander for $10, someone used it for a construction job, so the bearings need to be washed and lubricated
Partner
9:14 AM
Poland
Chinese on springs from the Jula supermarket. Swedish, 4-year-old, used, $25. The guy got angry because she didn't want to run. 2.5 turns of the L screw, apparently no one has turned it. It didn't even require cleaning, just sharpening the Sabre chain
NateSaw
3:14 AM
Maryland, USA
Is that a jred knock off?
Partner
9:14 AM
Poland
No, it's just plastic and a filter and the rest is like other porcelain / The fact that springs are made of porcelain, I haven't seen yet . The left side of the fan is different, the brake is also different, the handle is separate from the clutch cover , Maybe it's actually a copy
Partner
9:14 AM
Poland
Drill with 2 mechanical gears for $10, 35 years old, looks like new, something is wrong with the switch / I like quick repairs
TheDarkLordChinChin
My name Borat, I like you
8:14 AM
Ireland
I didn't buy it but I ended up with this today.
He said he must have it 30 years but I am skeptical.
He was using it one day it blew the gears connecting the power head to the shaft, said bits of them came out through the air filter 😰😰.
He said to do what I can with it. Thankfully he is in no rush as I got an fs450 to him yesterday for 350 euro. The 450 has a longer, narrower shaft. IMG_20231023_152500.jpgIMG_20231023_152426.jpg
Partner
9:14 AM
Poland
Nie kupiłem tego, ale dzisiaj skończyłem z tym.
Powiedział, że musi go mieć 30 lat, ale jestem sceptyczny.
Kiedyś go używał, wysadził koła zębate łączące głowicę napędową z wałem i powiedział, że ich kawałki przedostały się przez filtr powietrza 😰😰.
Powiedział, żebym zrobił z tym, co mogę. Na szczęście mu się nie spieszy, bo wczoraj kupiłem mu fs450 za 350 euro. Model 450 ma dłuższy i węższy wał.View attachment 394407View attachment 394408
View attachment 394409View attachment 394410View attachment 394411
a friend has a similar scythe for sale, Fs 420, a good old machine, a bit expensive because 333 Bidens
Partner
9:14 AM
Poland
and how much is too much now? I recently saw one in working order here for $333 / The correction in this price was Ms 044 and the newer Ms 440 is an expense for us at least. $500
Partner
9:14 AM
Poland
Grinder for at least 30 years for $10. I hope the switch can be repaired because the engine is very nice. Detachable power cord. Someone must have washed it because there is no grease / it's the spindle lock
