- 9:16 PM
- Jan 28, 2016
- Dike, Iowa
I picked up a snow blower that was intended to be used with a small skid steer, I plan to use it on my Stuck mini dozer. The auger/impeller is roughly 18" in diameter, any idea that kind of RPM it should turn? It will be powered by an independent 16 HP engine but I am limited to a 16" pulley on the end of the shaft. Even if I run a 3" pulley on the engine the impeller would be spinning almost 500 RPM with the engine running 2,500 RPM.
It appears to have been made to be driven by an independent engine as the mount looks to be factory and that was a 12" pulley on there when I got it.
Where do I go from here?
I think my grandson will let me use it if I need to.
Mark
Mark
