Time's Standing Stihl
Below me...
- 9:16 PM
- Apr 20, 2016
- Central Iowa
SoldCopy that. Hopefully I’ll get to check it out in person pretty soon. He is wanting $750 for it
howdy guy's
i've been have'in a hell of a time setting up my used grinder i bought.
does this pic show anything that would make it impossible or very hard to get the same results on both sides of the chain?
i'm wonderin' if the arm is the culprit.View attachment 103687
If it's off from side to side it's either the motor or the swingarm.howdy guy's
Yeah, I wouldn't exactly call them "polished".Wow, if you handed me that winning chain, I would be seriously pissed off...Proof is in the pudding I guess.
One thing that I noticed is the pictures of the links do not have marks above the rivets from the grinding wheel. They said at least number 3 was from a swing arm machine. I wonder if they are thinning the underside of the wheel to clear ?Seemed like a good place to post a link to a Madsen's & Oregon square grind contest. Go to the end of the catalog pdf to see the results. Pretty interesting.
http://www.madsens1.com/PDF/17catonlne.pdf
Laziness is my guess. When I ground I wouldnlet them go. Filing it's harder to do with a gullet in the wayAnother item that struck me as odd was the comments about the gullets. If they all picked up speed when they were cleared, why wouldn't the people sending them in do it. The multi stepped angles in the pictures were serrated looking.
If they did hit the strap, looks like it has been cropped out of the picture.One thing that I noticed is the pictures of the links do not have marks above the rivets from the grinding wheel. They said at least number 3 was from a swing arm machine. I wonder if they are thinning the underside of the wheel to clear ?
Looks like you have plenty of chain to grind. Good luck
Thanks Mike, had a lil time today to playN
Nice Clint!
