Adirondackstihl
- 11:02 AM
- Dec 4, 2015
- Upstate NY
Arm?That's arm on there!
Well yeah.....duhThe aluminum part is mine.
I posted that without reading the whole thread.Well yeah.....duh
Insert "eye roll" hereI posted that without reading the whole thread.
Here's the vice I won that Ryan @Mycamaro_68 made. Its stout! View attachment 95899And I noticed this is the second 250 in this thread but theres nothing wrong with it I just tossed it on there cause its fugging heavy!
Thanksagain Ryan.
It really is. The pictures don't do it any justice on how beefy and well thought out it is.Very nice!!
I'm glad you like it!Here's the vice I won that Ryan @Mycamaro_68 made. Its stout! View attachment 95899And I noticed this is the second 250 in this thread but theres nothing wrong with it I just tossed it on there cause its fugging heavy!
Thanksagain Ryan.
Scott,I will have saw vices for sale at some point, been to busy to get to them
How is this PanaVise holding up?Well, I got curious as I often do and found a reasonable enough deal on the 'heavy duty' 1" Panavise 400 to buy one just to play around with.
To work as a saw holder it only needs a 1" shaft with a bar end or whatever attached to it.
Like the smaller one it swings up/down 90 degrees and spins/pivots 360 in two axis.
Instead of mounted right on the bench, might be nice elevated a bit on a short pedestal or screwed onto a piece of 4 x 4 angle to be clamped in a bench vise.
Not the end-all-be-all of clamping strength but reasonable enough to be useful, will hold up 223cc worth of saws, just.
Hand tight with only that little knob even...
Would be better/easier with a 2" or so lever arm tapped into the smallish metal knob that comes on it, though remains to be seen how it would hold up to the increased tightening pressure.
Thanks for the input it’s been between this and a used powrarm vise the 1” hole seems very versatile but 1”x5-16 spacing is pretty versatile as well
Holding up well Bill, but I’m only pumping out 4 saws a month, max. I also rarely take it outa the 90* position.Just fine so far, doesn't exactly see daily use though.
Also I did add a short arm protruding from the tightening knob for a little more leverage/ease of use and it's holding up well to that additional abuse as well.
I've noticed a taller-armed bench mounted variation with a 90 degree saw mount in the background of several various peoples build threads, I'm assuming Al ( @drf256 ) is making/distributing them, he may have a better idea of how they do with a little more regular use.
