RIDE-RED 350r
- 7:41 PM
- Feb 8, 2016
- Blossvale NY
So as some of you might remember from my major thread jacking in the holiday giving thread, my ten wheeler plow truck at work blew the turbo and ran away when I was at work plowing Christmas morning.
Well, we got her into to the shop yesterday and started evaluating things. But real quick before I get into what we found and where things sit now, a bit of background. It's a 2004 Freightliner FLD112 Super Duty with a Pre-EGR Cat C-12. When it shut down after running away, it did not come to a sudden stop, but rather slowly came down and stalled. About 20 minutes after the incident, I bumped the starter and remarkably it willingly turned over without delay and actually tried to fire.
So having said that, our mechanic told me that sometimes a runaway will begin to ingest so much engine oil that it chokes out the air to the point it will stall out. So, we go about checking things over... Drained about 3-4 gallons out of the pan (10 gallon capacity), removed the oil filter and found it completely full. No metallic debris found in either. With that discovery, the mechanic stated he was confident that the bottom end survived. The turbo: we found that while the turbo shaft was broken in two, the compressor turbine was still present attached to the shaft and undamaged except for some mild abrasion from rubbing on the housing when the shaft bearing went. Pretty good indicator that turbo debris probably didn't end up inside the engine.
According to our mechanic, all of these things point to the engine surviving and able to work again with a new turbo, charge air cooler, air filter, oil, oil filter, and a thorough cleaning of the charge air piping, hoses, and intake manifold. So at this point, we are waiting for the new charge air cooler and turbo and will give her a try when we get those new parts on.
I'll let y'all know how it turns out. I am genuinely surprised at the possibility that the engine could survive such and incident!
