RPM In The Cut
Wanab
5:14 AM
USA
Just wondering what different saws are seeing. What's good, bad, better, best?
I am curious to what a stock 660 turns.
Wonkydonkey
Plastic member
10:14 AM
Sussex, UK.
I think thoughts have changed a bit over the yrs..
blunt vs sharp,
chip thickness,
smooth cutting,
angles of teeth!
Hard vs softwood,
sq ground/filed vs round filed, as well as Semi chisel vs full chis
Then you can add skip, semi or hyper skip.
these all change cutting speeds in the wood.
i will be interested to others thoughts on this, but once you go over 11/12k in the cut it don’t seem to cut any faster. There are other ways to eat through the log with some of the things is listed above.;)
Woodpecker
Sassy Madam
5:14 AM
Depends on the saw. What saw would you be referring to. Most are between 10-12K.
I guess it depends on if your talking in the cut or just for making pïss rev videos. Me personally I think you should be worried about in the cut… You know where the work actually gets done.
5:14 AM
Yea, ditto on that! I really hope they do return. In addition to seeing everyone, the image of you running one of your bike saws is stuck in my mind!
